In the future, someone could get one hell of a surprise if they turn off the downstairs socket circuit off and then get a shock from your socket when they unscrew it.
Worth bearing in mind.
This is the correct answer, dont put a 13a outlet onto a lighting circuit, this is what 5a round pin sockets are for (you'll see them a lot in hotels with the lamps on them, so that the wall switches control the plug in lamps around the room). Do this if you need to plug something into a lighting circuit.If you want to keep it 100% above board use of of these. Putting a 13amp socket in wouldn't be compliant.
https://www.screwfix.com/p/schneide...sp-switched-round-pin-plug-socket-white/8806j
You will need to change the plug on the camera or make up an adaptor if it has a wall wart.
That would be their own fault for not testing it first.In the future, someone could get one hell of a surprise if they turn off the downstairs socket circuit off and then get a shock from your socket when they unscrew it.
I don't think that'd stand up in court or your conscience really. Safety isn't about blame it's about, er, safety.That would be their own fault for not testing it first.
And not testing a circuit before working on it is about number 1 in the handbook for safety. Never assume it's not live. My conscience would be fine if people can't follow basic checks.I don't think that'd stand up in court or your conscience really. Safety isn't about blame it's about, er, safety.
And the fault of the installer for not labelling it which would be the sensible thing!That would be their own fault for not testing it first.
I didn’t say it was a requirement but if I did it, I’d label it takes 30 seconds and could save someone’s life!There is no requirement to label sockets with which circuit they are on. Yes it would be nice but it doesn't happen.
So could putting labels all over the walls to show where buried wiring is but that too isn't done because the rules are that you're to check before carrying out work.I didn’t say it was a requirement but if I did it, I’d label it takes 30 seconds and could save someone’s life!
What a stupid comparison, labelling a random socket is 10 seconds work and a sensible, practical safety step. Labelling walls for buried cables is neither practical nor sensible…..So could putting labels all over the walls to show where buried wiring is but that too isn't done because the rules are that you're to check before carrying out work.
