- 29 Nov 2004
- Omnipresent
Hi All,
The trusty old Gigabyte P55-UD5 motherboard in my main computer has finally had its time and developed a fault that causes it to power off randomly or not start at all. I've gone through all the usual testing (replaced the PSU as well) to no avail. So it seems like as good a time as any (Black Friday) to build a new rig. My computer is a hodge-podge of parts replaced and updated over the years, so i will keep certain components to keep the price down. I want to build a reasonably high-end machine that will last, as i use it to game/work/study/run vm's, etc.
I just need some advice on the components i have selected, as i have not built anything in a long time, so RGB and funky pre-built water cooling solutions are new to me. There is a wide range in pricing for MB's as well.
Budget is ~1500 max. I'll keep the gtx980 for the mo as only have 1080 screens and i can alway upgrade down the road. I've got PSUs and i like the full tower i have, it should fit anything new and has the attachment points for a rad at the top. SSDs and rust I'll keep and utilise. M2 drive for the OS will be whatever the fastest is at a reasonable price and size, i might get a 2tb sata ssd for steam library, etc.
Thanks in advance for any advice.
Current Spec
Intel i7 860 2.8GHz (With dirty great venom heatsink and fans)
Gigabyte P55-UD5 LGA1156 Motherboard
12GB DDR3 Ram
512GB SATA SSD (KEEP)
256GB SATA SSD
256GB SATA SSD
1TB Spinning rust (KEEP)
EVGA GTX980 (KEEP)
EVGA SuperNova P2 850w (KEEP as its only a few years old, otherwise i have a brand new Corsair 650w)
Corsair Obsidian 750D Full Towercase (KEEP)
New bits
My basket at Overclockers UK:
Current Spec
12GB DDR3 Ram
256GB SATA SSD
256GB SATA SSD
EVGA GTX980 (KEEP)
New bits
- 1 x Asus ROG Crosshair VIII Hero Wi-Fi (AMD AM4) DDR4 X570 Chipset ATX Motherboard= £389.99
- 1 x AMD Ryzen 9 5950X Sixteen Core 4.9GHz (Socket AM4) Processor - Retail= £709.99
- 1 x Crucial Ballistix RGB 32GB (2x16GB) DDR4 PC4-28800C16 3600MHz Dual Channel Kit= £149.99
- 1 x Corsair Hydro Series iCUE H150i Elite CAPELLIX RGB Performance Liquid CPU Cooler - 360mm (CW-9060048= £179.99
- 1 x Seagate FireCuda 530 1TB SSD PCIe Gen4 NVMe M.2 Solid State Drive (ZP1000GM3A013)= £164.99
Total: £1,605.45 (includes shipping: £10.50)
