Not an owner, but it's on my shortlist. Have heard a few things about QC issues though, which has kinda put me off.
Its currently £59.99 on OCUK the shape looks great trying to find something more comfortable than my current G pro wireless.
Zowie make great shapes. If they updated their mice in other areas they'd be top tier.
Cheers. Must give them another look so!I have not tried the older mice but they have updated their mice recently, they are now lighter the mouse wheel has been upgraded to 24 step and the paracord is amazing.
Which colour do you have what's the coating like?Im currently using this mouse as the model O wireless seems to be a hit or a miss with software/fimware issues Im getting, Latency seems fine to me in FPS![]()
Its white and coating is fine no noticable problems, Comparing it right now with a Roccat kone pro which is smoother and In my opion has a slightly sticky/adhesive feeling the onex is slightly rougher but in a good wayWhich colour do you have what's the coating like?
Its white and coating is fine no noticable problems, Comparing it right now with a Roccat kone pro which is smoother and In my opion has a slightly sticky/adhesive feeling the onex is slightly rougher but in a good way![]()
Just sent back my roccat kone could not get used to the optical buttons and the left mouse buttons was wobbly on mine, its a shame though as it has a nice shape i like the flat ergo shapes. I might get the Origin one x if this vaxee np-01 does not work out should be getting it next week.
when you say slightly rougher is it bit coarse?
Sounds good will see how the Np-01 goes im used to wireless but starting to dislike the G pro wireless shape...no its not coarse by any means just a tad rougher than the Kone maybe like Matt vs Silk and its got a good feel to it, the vaxee np-01 will be good as it much like the pwnage ergo and approx same size!
