Ipad Magic Keyboard is there anyway to seek forward in youtube ?
Caporegime
27 Nov 2005
Guernsey
Does anyone know if it possible at all to seek Back & forward by using the magic keyboard in things like youtube ?
On my MS PC i can simply just use the arrow keys but this doesn't work on the apple magic keyboard :(
Have you tried pressing J and L to go backwards and forwards by ten seconds?
double tap on teh screen or the track pad. Right hand side to go forward and on the left hand side of the screen to go back. whether the cursor is at on screen it will either seek forward or backwards.
you just double tap by the amount you want to go forward. The more you double tap the more you go forward or back
This works Thanks :)
Hoping that apple will add support to do this with the arrow keys at sometime
(Be interested if the MacOS supports this on a MacBook)
