Small or large upgrade?
9 Jan 2011
Hereford
Hello all,
My pc is getting on a bit now the specs are in my signature. I am looking to upgrade to a new PC as mine now struggles with most new titles. I pretty much do a little bit of everything in terms of workload but nothing seriously heavy at the moment.
I am really stuck on what to choose to be honest or if i should wait a little longer for the AMD refresh before i decide. I am uncertain about staying on DDR4 although I don't think it will matter too much for the near future but i think it may become an issue once DDR5 is utilized and more optimized over the next few years.
I would prefer to go AMD and originally was eyeing the 5800X but due to Intels new release the 12600/700K becomes more compelling.
I am wondering if its worth just buying a cheap mobo, cpu, memory etc now and just re-purposing my old case as it is still okay to use. To then maybe do a full system upgrade including a GPU in 2-3 years time.
or should I spend more money now on the same said items to have a fresh build and just update the gpu later.
Budget ideally max would be about £1000 (this would include CPU, MOBO, RAM, SSD, CASE, COOLER) will be using PSU, GPU, Soundcard, WIFI from old machine.
My basket at Overclockers UK:
Total: £887.93 (includes shipping: £0.00)
Usecase: Gaming, Music Production, Light Photoshop/Video Editing & Coding is the workload. I also stream from time to time.
whats your main use for the PC?
If its just gamihng then the 5600x is good enough for even the newest games.
Total: £765.47 (includes shipping: £14.70)​
You coudl reuse your corsair H100 with an AM4 bracket (i would guess).
Thanks for your replies. I forgot to add I dont need a PSU. I will be re-using the SuperFlower Leadex I have.
I have updated the original post with my original build plan if I went all out.
Either AMD or Intel would be great for your use case.
the 5800X is a bargain right now and it really depends on what you want to achieve.
A 12600K would be my go to for most scenarios including video editing and/or gaming.
what I’m saying is, go for either one. There’s no bad option.
going ddr5 not worth it..one, out of stock so people paying scalpers now to get them, 2 when are in stock, more than double ddr4 for similar performance at the mo..couple that ddr5 mobo are bit more expensive, in 2/3 years when mainstream ram is ddr5, the money you save now will more than offset upgrading your mobo, and ddr5 in the future will be a lot better also, so you'll be upgrading that too.
I'd go 1tb nvme drive..from what i remember reading awhile back the larger drives have better read/write performance and ..i may be getting muddled on that so need to check...
https://www.anandtech.com/show/13760/the-western-digital-wd-black-sn750-ssd-review small diff in case of SN750, don't know if that actually means anything real world
Ahh shoot! thanks for the information guys I actually went with the MSI board in the end. I was on going to choose the TUF but I'm not a big fan of Asus due to poor experiences in the past. Also wanted to skip Gigabyte as they seem to be skimping a lot these days. Heard good things about the MSI board though.
On the Storage front, I barely use anything I also have a 700GB Sata SSD. I was going to get the SN850 1Tb but £60 for the 500GB is all i will realistically need for a while. I can always grab more later if needed.
