Is my external hard drive broken?
12 Feb 2006
Surrey
I know this is for a hardware device, but figured it might be software related.
I have a 2tb WD passport which used to work on my xbox one for recording my game footage, that I'd plug directly into the xbox, and then plug directly into my pc to copy the files once full, empty, and back into xbox.
It's now stopped working on both devices. The pc recognises it by making a noise when plugged and unplugged, but it doesn't show anything.
My xbox series x did recognise it and said it needed formatting, but it didn't seem to do anything.
Anything I can try to get it back to life?
Pet Northerner
Don
29 Jul 2006
Newcastle, UK
In windows, plug in the drive and go to Disk Management.
If the drive exists and you can see partitions / unused space, you could try to delete all it's partitions and create a single, clean FAT32 partition.
OP
12 Feb 2006
Surrey
doesn't show anything for this drive, tried unplugging and plugging in again. makes all the right noises but nothing. shows a light on the drive too.
21 Dec 2019
Planet Thanet
Yeah always try a different cable
And different usb ports/other pc etc
Failing those try to remove the hard drive from the enclosure
And then test it to rule out the enclosure not the drive is faulty
Though Google it first to make sure it's got a standard SATA drive in there
Somewhere like instructables website will probably show
How to dismantle it
