Hanging a heavy mirror above fireplace
28 Nov 2004
Birmingham
Hi everyone
I would really appreciate some advice here.
I have a new heavy round mirror (it's just under a meter wide and metal) and I want to hang it above my fireplace.
The wall is plaster over brickwork (chimney) and the mirror has a single hole to hang at the top.
I know I need an appropriate screw and wall plug but the issue is the ones I have just won't cut the mustard I don't think.
I would appreciate any advice on which screw and plugs to buy to securely hang this metal beast of a mirror!
Thanks ❤️
I have these funky metal Rawl plugs which have a bolt through them. They're designed for holding heavier weights, I used them to hold my bike on a wall. Might be called wall anchors or something. I can dig out a link if needed.
Quartz - not 100% sure but I'll see if I can pop it on some scales I'd say 10-15Kg at a guess.
Cleisthenes - a link would be great thank you!
10-15kg is nothing, standard rawl plug will hold that weight in brick but something like a fischer UX8 gives a bit more quality to the fixing , most of the weight will be on the screw so you want something quality. I see no reason to use something more heavy duty like an anchor bolt on such a weight.
I'm thinking that you might have it so that the bottom is directly on the fireplace so the fireplace itself supports the mirror.
Depends if your fixing will be penetrating into the brick or not i.e. how thick is plasterboard, is there a gap between, and how long a fixing can you use.
If you can get decent penetration into masonry then @200sols said, 15kg is no problem at all for even a well installed red wall plug.
If you aren't able to reach into the brick, your best best is one of these, which I imagine might be what @Cleisthenes means.
M5 x 71 Heavy Duty Metal Zinc Plated Steel Molly Bolt (Pack of 5) Hollow Drive Wall Anchor Screws Set for Drywall Plaster Wall Dry Plasterboard Tile Block Gypsum Board (71mm Long) M5x71 : Amazon.co.uk: DIY & Tools
Your problem might be if you have a small gap that is basically no good for either solution. But I think with either a very long wall plug (if the gap is quite small), or by drilling away some of the masonry and fitting in a metal plasterboard fixing (if the gap is quite large), there's a tidy solution.
I had to hang a heavy oak mirror, I put a batton of scrap wood across, with 8 or so dewalt nylon screws, and hung the mirror on that. I reckon I could hang myself of it it's that strong.
Unfortunately screwfix don't seem to sell them any more but these look like the ones. The nylon really grinds/adheres to the plasterboard.
https://www.ffx.co.uk/product/Get/Dewalt-Dfm4120000-0075352966908-Zip-It-Nylon-Include-Screws
If you're going into brick you'll be all good with normal raw plugs
I've used nylon ones like that before and they got chewed up while I screwed them into the plasterboard. Read a lot of similar experiences too. Maybe those dewalt ones are better quality, and I don't doubt you managed well with them from what you said, but I'd be cautious about these.
Usually only happens when the pilot hole is too small. I usually add some washing up liquid / soap / spit around the thread which seems to help too
OP said plaster over brick. Not plasterboard.
A decent length / diameter screw + plug that reaches into the brick won't have any problem holding a mirror - even if it's made of lead.
D'oh I misread. Agree with this. Just go with a brown wall plug to be safe, not like they are at all expensive.
I'd just go with a standard wall plug or fischer duo plug. (saying that I've never hung a particularly heavy mirror!)
I believe fischer duo plugs say theyre rated to 200kg or so
Thanks for everyones input on this. Much appreciated. I got a decent set of larger screws w/ wall plugs and the mirror is now hanging securely on the wall.
