- 8 Jan 2011
- London, UK
Hi guys, I just read over on the aqua computer English forums, that EK varder fans do not work with splitty9.
One of the explanations given is that there is something particular about the electronics of EK varder fans that doesn’t work with splitty9.
The solution to fix this issue is to apparently cut the tach (rpm) line of each fan, or, remove the pin on each splitty9 header that receives the tach line of each fan.
Has anyone heard of this issue? Has anyone used recent varder fans with this setup? My fans are EK varder x3m rgb.
I am about to put a build together with these components, so am going to be pretty stuffed if this is a real issue!
Any comments much appreciated
