Deleted User 298457
Deleted User 298457
Just adjust your headYour Christmas tree is wonky.
A new cat water fountain
I can't look past that Jared Leto joker canvas....... it's not to my taste lets leave it at that.![]()
A house cat?What sort of self respecting cat would drink from that instead of lets say a dirty puddle.
Is this a renault 1.5dci by any chance?Rubbish picture but my ex had a warning light and limp mode dci 1. 5 engine the garage that serviced it failed to diagnose even with a test drive.
One 30quid boost solonoid valve and its fixed and transformed
Its a micra 1.5dci but probably the same part tbh, sits on a bracket underneath the air intake down by the radiator, the car was flat as a pancake before changing
Where'd you get that rug?
After! Very pleased with it. Though I did just spend over 100eur on frigging bulbs! Needed light over the table (soon to be replaced but chairs are new) and light over this end (something going in this space hopefully next week) so this was a good choice. I really like how it's looking and my touch on the place since being a bachelor pad![]()
Is it not a clock?What's the odd speaker on side board? Not seen anything like that previously.
They've gone out of business, because… well, look at it.![]()
I think they're satsumasWhat's the odd speaker on side board? Not seen anything like that previously.
Weirdly though the lght that came on was the water in fuel light (the filter had been done, good fuel so it wasnt that) and fault code was for the inlet sensor that she changed after serviceYes same engine, and a massively common fault![]()
