Cpu prices
30 Nov 2005
I want to build a new pc but the prices seem to have gone higher and higher, when do we expect s return to normal?
28 Jun 2013
I find the cpu prices simular to 2017, the best 8th gen i5 and i7 were £260 / 390 odd at first if i remember and the 12th gen seems much the same
Man of Honour
25 Oct 2002
Hampshire
To be fair, he actually has a point in the upper-budget sector, I talked about this in a thread a few months back ( https://forums.overclockers.co.uk/threads/no-cheap-ryzens.18936010/ ). Basically, the issue is all the cheap ryzens have dried up, so there is no value in that end of the market. You have to go mid-range to find value.
I recently got a 11900F for £220 which I think is decent. 5600X is similar. But under £200 it's very meh, I mean I got a 2700X for £141.70 22 months ago (3600X wasn't much more). What can you get these days for under £150? Not much of an improvement over 2 years ago from what I can see... a 11400F which is no better than a 2700X, and AMD nowhere to be seen, maybe a naff 4 core chip?
I've been upgrading PCs since the 90s and I don't think I've ever seen the <£150 segment this stagnant, ever. Admittedly you have to factor in inflation but I never had an issue getting chips in this pricerange until now.
17 Aug 2009
my weekly shopping hase gone up 15% , fuel has increased, heating up 30%
I think you will find this is the new normal
Man of Honour
25 Oct 2002
Hampshire
If you factor in DDR4 costs system builds aren't really any more expensive than they used to be. I built a Ryzen system 4 years ago and the RAM cost £150 for 16GB 3000mhz which was cheap at the time. So if you buy 32GB RAM it is faster and costs £200 less than 4 years ago. So you could build e.g. a 5800X system for the same price as a 1600 system back then.
I would look at the total cost of Mobo+CPU+RAM and compare with your normal builds, obviously this is on the assumption you need new mobo and RAM.
15 Oct 2019
Uk
Cpu <£200
Have a look at the 10400F/11400F as those chips are currently the best bang for your buck, if you can wait for another month then the 12400F + B660 combo should be out and the 12400F will be slightly faster than a 5600X for £100 cheaper.
