Permabanned
- 25 Oct 2021
- Geneva
Yep. UK feels like 3rd world country when it comes to internet connectivity.
That may look like the case but the majority of people in the UK won't have the hardware to utilise a 10GbE link.
DCs will already be linked with at least 10GbE.
I'm usually sympathetic to "the internet in the UK is bad" arguments but being unhappy there isn't widespread access to 10Gb symmetric residential products is a sign that you need to gain a bit of perspective.
+1 on the “this post is just ePeen”.
I had a symmetrical 2Gbps leased line in the office and I dropped it to 1Gbps simply because to max it out for backups I needed a 2Gbps connection at the other end and that simply was silly. So I dropped it to 1Gbps and I can fully utilise that.
For a home user, 1Gbps is enough to max out most home networks and that pretty much makes it the current sweet-spot. Even then, most systems you connect to won’t give you 1Gbps all to yourself so again, it’s not exactly vital that you have it.
I know plenty of people on the standard Openreach VDSL 40/10 or 80/20 packages and they’re perfectly happy. It’s the poor people stuck on ADSL at less than 20Mbps are the ones who need a speed increase.
I've got the 900mb FTTP service and the limiting factor is the other services, by a long shot. I don't think I've even got close to 50% utilisation in the real world, outside of speedtests.
Tell us more about your setup if you don't mind. Router? Firewall? Is your LAN copper or fibre? What's your array like? ZFS? Are you running any servers or just one jumbo desktop/workstation? Hopefully the Engenius stuff works out for you, Wendell seems to like them but I've had good luck with Ruckus personally.I'm not typical user... I'm already maxxing out the 5GbE port on this motherboard:
And that's to a spinning platter array.
Not everything of course, but you'd be surprised just how many services out there now can leverage a connection over 1Gbit now.
12TB in 6-7 hours is kind cool... when the new NIC arrives, I should be able to max out the array.
EDIT: It settled down to just over 160MB/s constant:
What ISP are you with?
I seem to be able to always max out my connection from any popular services with the right infrastructure.
Since I have FTTP, any upgrade to 10Gbps and beyond is easy as it only requires changing the equipment used.
Cool.Tell us more about your setup if you don't mind. Router? Firewall? Is your LAN copper or fibre? What's your array like? ZFS? Are you running any servers or just one jumbo desktop/workstation? Hopefully the Engenius stuff works out for you, Wendell seems to like them but I've had good luck with Ruckus personally.
Thats fair enough, but you opened this post by having a pop at how awful broadband was in the UK. I can get a 100Gb leased line in the UK, if I want to pay for it. I assume you have the Internet L package, which seems to be available in a very small number of locations whereas the identically priced M and S packages (300Mbps and 100Mbps) are more commonly available but still not everywhere. I would suggest that more people in the UK can get the 900Mbps package than can get the 300Mbps package in Switzerland. Just ePeen. And anti-British too.
