It doesn't matter what it is rated for. It needs to support PPS charging.
Otherwise it will revert to 18W PD3 charging if the charger supports that.
Will bear that in mind, thanks
Will bear that in mind, thanks![]()
Do the Pixel updates still drop on the 1st Tuesday of the month ? Not had any for ages since I was using a Pixel 2XL.
Thank you. It's gonna be a blast from the past mashing the "Check for update" buttonRumours are it'll be today... probably later on in the day
Wonder if any issues will be addressed ? I don't use 5g but my best mate has had lots of issues when 5g drops it does not fall on to 4g or even 3g bit just indicated no signal.
Bose music app is utter garbage, it sees the cans but won't connect after multiple attempts. Is there any advantage to having the app running?
Edit, actually now they won't connect at all, even via Bluetooth settings on the phone. Maybe I'll punt them on eBay after all.![]()
It's coming out next week for Pixel 6 and 6 ProNot seeing the update yet.
