Can't decide out of these 2 OCUK prebuilts.
13 Sep 2021
Glasgow
The latter has a newer CPU, even if it’s an i5, and the same GPU
The 12 series brings quite a nice jump in performance.
Thats what Id go for
Yea go for the Sabre. You can double the memory for £45. Also you can save money by removing Windows and getting your own for a few quid.
I would go with the Sabre build, but you are going to want a better psu as the one included is more than likely a Kolink. Something like the MSI unit below would be a good idea.
My basket at Overclockers UK:
Total: £95.45 (includes shipping: £10.50)
I think the problem with suggesting swapping the PSU is that the OP probably wants a pre-built to avoid doing any building. The included PSU may not be what we would recommend, but for a pre-built with 3 years included warranty, I would just leave it as it is.
If you ring up OCUK they will swap the psu for the unit you actually want when you buy a prebuilt.
I've not phoned up yet, i ended up with a really busy day at work yesterday so gonna phone up within the next hour, seems like a good spec pc for the price :)
Yup, recommended to a few people..think the best Ocuk have at the mo..couldn't self build for that price with gpu 3070ti prices, though another seller did have some 3070ti's for £899 this am so could get a self build for close, but sold out quickly(cheapest I've seen is £1049 at mo now )..remember, you can swap anything you want, ie case/ram/mobo/psu/fans etc..they'll ask for an email with changes, then send you a revised price where they subtract what's on original and add what you want, so you can custom it to however you want
Aw really? that's pretty good then! i tried phoning up but to no avail, i decided to leave a webnote with spec in it and hopefully they'll get back to me :P
Aw really? that's pretty good then! i tried phoning up but to no avail, i decided to leave a webnote with spec in it and hopefully they'll get back to me :p
what, they didn't answer? Just had a look at the 600S case you like....bit of a monster:cry:...what you going to put in it on top of the prebuild?
Yea I'd keep calling, if you wait for web note you may wait too long and the deal may end.
Not planned that far ahead yet haha, but honestly love the case, i'm not the biggest rgb person so it works for me :)
Also, think it would be worthwhile going for the 12700KF?
Do you think so? I'll try phoning again then
Tried again, just keeps ringing with no answer from them
yeah, they do pick up eventually...12700kf up there with the 5900X, so a great cpu.. the extra cores may help and you do get a slight uplift in fps from yt that I've seen using 6900XT and 1080p, but at 1440, doubt you'll really see much of a diff gaming for forseable future,..saying that I got a 5800X over 5600X as I wanted the extra cores, just to try and future proof myself for a bit longer before needing to upgrade... I'd be tempted for the extra £20 to get the k verion with build in graphics, just so that you can still use your pc for general stuff if ever you're without the dedicated card(breaks, or sell before buying a new one etc)
Cheers, appreciate the advice :) just got a quote back with the 12700kf and the upgraded psu for 1925, though one of the ssds is missing from said price, still happy with the price quoted though! :)
