Will try that cheers, seems to run pretty well for RDNA2.Grab the free online experience from steam. It's a cracking game after the disappointing release of Battlefield I have been enjoying Halo instead.
Seems to be getting traction, same for myself not played much Halo in the past but happy to take it in. Where's the 3090 in the resuts?![]()
90 is the flagship not 80nice, a topic i can feel right at tome
pretty disrespectul performance on ampere
its so bad. their flagship 80 tier GPU can't even push 60 fps at 4k, while rx 6800xt gracefully pushes 70+ fps
GeForce RTX 3080: The New Flagship
Starting at $699, the RTX 3080 is the perfect mix of fast performance and cutting-edge capabilities, leading Huang to declare it NVIDIA’s “new flagship GPU.”
Designed for 4K gaming, the RTX 3080 features high-speed GDDR6X memory running at 19Gbps, resulting in performance that outpaces the RTX 2080 Ti by a wide margin.
It’s up to 2X faster than the original RTX 2080. It consistently delivers more than 60 fps at 4K resolution — with RTX ON.
well, upcoming year will see the release of ddr5 assisted zen 4 cpus with monstrous 3d cache, alongside with 4080-4090.Pc performance is terrible, the consoles are achieving twice the performance compared to equivalent amd pc hardware, nevermind Nvidia - it's even worse for Nvidia, the the Xbox series consoles run better than an rtx3090 despite those consoles being equal to an rtx2070 and to top it off those consoles have an ryzen 3700x cpu which runs the game 20-30% slower than a newer CPU.
Put that all together and the game essentially is only achieving 50% of the performance it should be on PC, take all those bars on those graphs and DOUBLE THEM and that's the performance this game should have on PC
Not really, the game was built and developed as an Xbox first party title so has the advantage of all that optimisation for RDNA graphics cards.Those numbers looked skewed as AMD appears to beat Nvidia.
GOW will support FSR and DLSS though. I haven't seen either in Halo Infinite yet. Although someone in the beta stated that Halo Infinite did have FSR support during the beta. So, I can only assume it will come out at some future point.
Poor performance in the open world for me. Seem to match the computerbase results around 80fps max settings at 1440p.
I tried df optimized settings which is slightly better at 10-15 more fps but still not great. Doesn't feel smooth, I think it's some animations running 30fps.
Interesting, thanks for posting this information.Poor performance in the open world for me. Seem to match the computerbase results around 80fps max settings at 1440p.
