New Build Z690 & i9 - Advice
28 May 2011
in a house
What would you change and why?
Thanks.
Levon
That build doesn't make a lot of sense in terms of value for money. I mean £500 for 32GB Ram is just crazy.
The 12700K has the same amount of P-Cores, so unless you need the extra E-Cores then you can save £200+ over the 12900K.
The regular O11 Dynamic fits a standard ATX psu.
The Z690 Tomahawk will do the same thing as the Z690 Hero for half the price. If you want Asus then there are some DDR4 boards for £250+. The Z690-A Gaming Wifi DDR4 for example is still £200 cheaper than the Hero.
A 32GB kit of DDR4 for under £100.
Good AIO and 6 extra case fans. You could go 6 intake and 3 exhaust. If you don't care about RGB then there is a non RGB version for less.
Solid 1000W psu. No need to spend £300+ on one.
Changed the SSD's to 1 x Gen 4 and a Gen 3.
What gpu do you have ?
My basket at Overclockers UK:
Total: £1,609.02 (includes shipping: £13.20)
