Need help to lose my glasses...
18 Jan 2007
Dorset
I have a Saab 9-5, perfect for my work commute: quick enough (presently remapped at 235 bhp), economical enough (28 mpg average), comfortable.
However, it looks like it's wearing Dame Edna's glasses! I'd like to change headlight surrounds to either matt black, or satin chrome. What would be the best way to achieve this?
1 Jun 2014
If you're going to redo the headlight surrounds from silver IMO it's going to look weird the grille surround still being 'chrome', my vote would be just trying to make them darker, rather than full black..
As above, plastidip is probably the best choice since it can be peeled off relatively easily.
13 Feb 2003
Sheffield
Body colour would probably camouflage them best if you did the grille surround as well, but painting chromed parts is always fraught with problems or works out expensive if done properly (blasted to strip the chrome, epoxy primer, paint & clearcoat)
Plastidip seems popular. Being slightly flexible it'll be less likely to chip off than paint, and easy to strip & redo if it does.
Or consider wrapping them.
OP
18 Jan 2007
Dorset
I think they're the winning options if I go for it, will have to figure out how they unclip
Caporegime
22 Oct 2002
Boston, Lincolnshire
Lots of people take them off and plastidip them. Does look a lot better. At least with plastidip it is easily reversible. You need to do the grill as well as otherwise it does look a little odd.
Then again I do prefer the second facelift but then I am biased ;)
OP
18 Jan 2007
Dorset
Another 9-5 owner?
Caporegime
22 Oct 2002
Another 9-5 owner?
Yes had my Aero coming up to 7 years now! Has taken me all over Europe.
Stage 1 tuned. Lowered on Eibach springs and Sachs dampers plus fully polybushed. Still very comfortable but can hustle a b road a little better than standard.
I was doing a 70 mile commute in it during lockdown and managed 33MPG over several thousand miles.
OP
18 Jan 2007
Dorset
Very nice! I had a 1999 2.3T estate a few years ago, I loved it, and still think it's the best looking 9-5. Had the best rear lights :D
I've got a stage 1 NoobTune at the moment, plan for next year is to put the bigger turbo on, another remap, and a brake upgrade.
Did a trip up to the NEC recently, managed 35 to the gallon! Was very pleased with that :cool:
