- 4 Jul 2006
Anybody have this case and have such a monumental hard time getting the screws out of the shroud, got 3 philips and flat heads and I swear these things are soldered in and there is one by the bottom of the case that will not come out and I swear to god I am losing it.
I have been at my build for an hour and all ive done so far is removed 8 screws (6 were to remove case sides), I thought id get a big case, everything should be roomy and easy to do, LIKE **** IT IS.
I am so close to seeing if I can return this, im sweating like a pig, my back is killing me and I have only got as far as removing half a dozen screws, worst case ever.
Edit
I give up, over tightened screw has defeated me, this thing is in WAY too tight and it is needed to remove the shroud, why are these not just thumb ones, the case is big enough.
Edit
. Looking in the accessories box just now, it seems I have more types of screw than are listed in the manual. I don't know where they came from; but I don't recall needing to dig around for spares from anywhere else.
