- 19 Nov 2021
- Portsmouth
So I have a Ryzen 5 3600 running on a Gigabyte X570 GamingX (f36e bios). Coolermaster liquid lite 240, with radiator mounted in the top slot of a corsair 800D case.
Chipset and VRM temp around 50 under load, but CPU goes up as high as 80 in the CTR 2.1 test suite (and it says weak cooling detected). Idle it sits around 40 degrees CPU temp. CTR2 shows CCX1 being consistently cooler than CCX2 (10-15 degrees)...
I would have expected somewhat better from a liquid cooler, to be honest the air coming out the top of the case through the radiator doesn't even feel warm.
Are my expectations unreasonable, or have I done something wrong with the install (ie, should I look at pulling it out, cleaning off any thermal paste, applying new stuff and trying again?)
Thanks
***ClockTuner for Ryzen 2.1 RC5(ver.23) by 1usmus***
AMD Ryzen 5 3600 6-Core Processor
GIGABYTE X570 GAMING X
BIOS ver. F36e SMU ver. 46.71.00
TABLE ver. 2361347
DRAM speed 3200 MHz
12/17/2021 15:02:39
P1
P1 PROFILE has been restored!
P2
P2 PROFILE has been restored!
PX
PX PROFILE has been restored!
You have unique processor, 2 CCD's!
Phoenix ready!
Cinebench R20 started
Cinebench R20 finished with result: 3486
Voltage: 1.308 V PPT: 88 W Temperature: 79.5°
15:04:49: Silicon FIT measurement started...
15:05:08: Silicon FIT measurement done!
15:05:08: Stress test stopped.
CCX COEFFICIENTS
CCX# 1 0 CPPC 127
CCX# 2 25 CPPC 116
CORES ORDER (from the best to the worst)
### CPPC FIT
1 С02 С06
2 С01 С04
3 С03 С03
4 С04 С02
5 С05 С01
6 С06 С05
AVX light mode
Cycle time: 60000 ms
Reference frequency: 4050MHz
Reference voltage: 1300 mV
Voltage step: 6 mV
Manual overclocking mode enabled
15:05:11: Saving temporary settings...
15:05:16: CCX1 (127): 4050 MHz, 1300 mV
15:05:16: CCX2 (116): 4050 MHz, 1300 mV
15:05:16: Step# 1. Diagnostic VID: 1300 mV
15:05:16: Stress test 1 started...
15:05:27: Stress test stopped.
-WARNING- Weak cooling system was detected!
Alternative diagnostic mode is activated
15:05:29: Stress test 2 started...
15:06:03: Stress test stopped.
15:06:04: CCX1 (127): 3925 MHz, 1200 mV
15:06:04: CCX2 (116): 3925 MHz, 1200 mV
15:06:04: Step# 2. Diagnostic VID: 1200 mV
15:06:04: Stress test 1 started...
15:06:39: Stress test stopped.
15:06:40: Stress test 2 started...
PCI-MUTEX holding time has expired!
Sending a command in an insecure way!
15:07:14: Stress test stopped.
15:07:15: Step# 3. Diagnostic VID: 1194 mV
15:07:15: Stress test 1 started...
15:07:49: Stress test stopped.
15:07:51: Stress test 2 started...
15:08:25: Stress test stopped.
15:08:26: Step# 4. Diagnostic VID: 1188 mV
15:08:26: Stress test 1 started...
15:09:00: Stress test stopped.
15:09:01: Stress test 2 started...
15:09:36: Stress test stopped.
15:09:37: Step# 5. Diagnostic VID: 1182 mV
15:09:37: Stress test 1 started...
15:10:11: Stress test stopped.
15:10:12: Stress test 2 started...
15:10:47: Stress test stopped.
15:10:48: Step# 6. Diagnostic VID: 1176 mV
15:10:48: Stress test 1 started...
15:11:22: Stress test stopped.
15:11:23: Stress test 2 started...
15:11:58: Stress test stopped.
15:11:59: Step# 7. Diagnostic VID: 1170 mV
15:11:59: Stress test 1 started...
15:12:33: Stress test stopped.
15:12:34: Stress test 2 started...
15:13:08: Stress test stopped.
15:13:09: Step# 8. Diagnostic VID: 1164 mV
15:13:10: Stress test 1 started...
15:13:44: Stress test stopped.
15:13:45: Stress test 2 started...
15:14:19: Stress test stopped.
15:14:20: Step# 9. Diagnostic VID: 1158 mV
15:14:20: Stress test 1 started...
15:14:55: Stress test stopped.
15:14:56: Stress test 2 started...
15:15:30: Stress test stopped.
15:15:31: Step# 10. Diagnostic VID: 1152 mV
15:15:31: Stress test 1 started...
15:16:06: Stress test stopped.
15:16:07: Stress test 2 started...
15:16:41: Stress test stopped.
15:16:42: Step# 11. Diagnostic VID: 1146 mV
15:16:42: Stress test 1 started...
15:17:16: Stress test stopped.
15:17:18: Stress test 2 started...
15:17:52: Stress test stopped.
15:17:53: Step# 12. Diagnostic VID: 1140 mV
15:17:53: Stress test 1 started...
15:18:27: Stress test stopped.
15:18:28: Stress test 2 started...
15:19:03: Stress test stopped.
15:19:04: Step# 13. Diagnostic VID: 1134 mV
15:19:04: Stress test 1 started...
15:19:38: Stress test stopped.
15:19:39: Stress test 2 started...
15:20:14: Stress test stopped.
15:20:15: Step# 14. Diagnostic VID: 1128 mV
15:20:15: Stress test 1 started...
15:20:49: Stress test stopped.
15:20:50: Stress test 2 started...
15:21:24: Stress test stopped.
15:21:25: Step# 15. Diagnostic VID: 1122 mV
15:21:26: Stress test 1 started...
15:22:00: Stress test stopped.
15:22:01: Stress test 2 started...
15:22:35: Stress test stopped.
15:22:36: Step# 16. Diagnostic VID: 1116 mV
15:22:36: Stress test 1 started...
15:23:11: Stress test stopped.
15:23:12: Stress test 2 started...
15:23:46: Stress test stopped.
15:23:47: Step# 17. Diagnostic VID: 1110 mV
15:23:47: Stress test 1 started...
15:24:22: Stress test stopped.
15:24:23: Stress test 2 started...
15:24:57: Stress test stopped.
15:24:58: Step# 18. Diagnostic VID: 1104 mV
15:24:58: Stress test 1 started...
15:25:33: Stress test stopped.
15:25:34: Stress test 2 started...
15:26:08: Stress test stopped.
15:26:09: Step# 19. Diagnostic VID: 1098 mV
15:26:09: Stress test 1 started...
15:26:43: Stress test stopped.
15:26:45: Stress test 2 started...
15:27:19: Stress test stopped.
15:27:20: Step# 20. Diagnostic VID: 1092 mV
15:27:20: Stress test 1 started...
15:27:54: Stress test stopped.
15:27:55: Stress test 2 started...
15:28:30: Stress test stopped.
15:28:31: Step# 21. Diagnostic VID: 1086 mV
15:28:31: Stress test 1 started...
15:29:05: Stress test stopped.
15:29:06: Stress test 2 started...
15:29:41: Stress test stopped.
15:29:42: Step# 22. Diagnostic VID: 1080 mV
15:29:42: Stress test 1 started...
15:30:16: Stress test stopped.
15:30:17: Stress test 2 started...
15:30:52: Stress test stopped.
15:30:53: Step# 23. Diagnostic VID: 1074 mV
15:30:53: Stress test 1 started...
15:30:57: Thread# 10 fall down!
15:30:57: Stress test stopped.
15:30:59: Step# 24. Diagnostic VID: 1080 mV
DIAGNOSTIC RESULTS
CPU VID: 1080
CPU TEL: 1040
Max temperature: 79.1°
Energy efficient: 3.77
Your CPU is SILVER SAMPLE
Recomended values for Undervolt:
Reference frequency: 4025 MHz
Reference voltage: 1175 mV
Phoenix deactivated!
Thanks
TABLE ver. 2361347
DRAM speed 3200 MHz
12/17/2021 15:02:39
P1
P2
PX
Phoenix ready!
CCX COEFFICIENTS
CCX# 1 0 CPPC 127
CCX# 2 25 CPPC 116
### CPPC FIT
1 С02 С06
2 С01 С04
3 С03 С03
4 С04 С02
5 С05 С01
6 С06 С05
AVX light mode
Voltage step: 6 mV
DIAGNOSTIC RESULTS
CPU VID: 1080
CPU TEL: 1040
