Images of items I have purchased (except trainers [no feet pics]) - Do NOT use imgur, postimage or imgbb!
It was cheap on marketplace, I couldn’t say no. Know nothing about go karts so off to google then onto eBay! But I do know it’s missing quite a lot of parts
http://www.wiltec.de/?utm_source=barefamting&utm_medium=youtube&utm_campaign=influ
Get yourself an engine from these guys! Can get a 9hp one (looks like a 4 stroke chassis. LIve rear axle, bearings and sproket and you'll be starting to get somewhere. I have messed around with 2 now. They are in my garage :P
Get yourself an engine from these guys! Can get a 9hp one (looks like a 4 stroke chassis. LIve rear axle, bearings and sproket and you'll be starting to get somewhere. I have messed around with 2 now. They are in my garage :p
Thanks, I’ll take a look.
I can’t see any markings on it, other than the MSA mark so no idea what it is.
I’ll get the vernier and tape out tomorrow and get some measurements and get ordering.
Yet another ebay bargain. Even though I already have a 1/2" GS80A ratchet, I couldn't resist this SR80A for £48. The Blue point 3/8" adapters cost £10 which seemed pretty good as the UJ alone is near that much.
Those FE cards are a stunning design. Looks great in there.
Aye the build quality is immense. It's so heavy yet there's no sag and it's a smaller form profile than the 2070 Super I had too.
Is it quiet?
More coil whine noise in some games than my outgoing Gigabyte 2070 Super Gaming OC but the fans are quieter. When not in a game the fans are not spinning so it's basically 0dB, same as the 2070 :p
The only annoyance with the FEs is the adapter needed for the PCIE Power. I've got a thick BlackIce GTX in the bottom of my case and it's tight between the adapters and the fans.
There's custom PSU cables offered direct with the FE connector on so I'll order one of those soon
I've been tempted with one of those cables. Although I'm lucky. Only having a 3070FE they are slightly better looking.
Someone else mentioned those cables, won't make a difference to me as the stock one is so tucked in anyway and inside this case is pretty invisible really.
