Can I ask why you made the changeI made the same change and would consider it a sidestep really. The 12600K is definitely easier to cool though and overall I’ve found the intel system more stable.
Hi whats your opinions on this?
Is a i5 12600k a downgrade, upgrade or sidestep from a r9 5800x when taking into all the considerations of newer tech, future proofing etc etc
tia
I have actually thought of doing that, they are £449 atm on ocuk....but cant make my mind up....fancy something new but then when you put in the fact to go for intel there is a new board to buy and in my case I would need a waterblock as well then it seems a lot of money for little gain. If money was not an issue then I would go for it with the i9, but i have a budget off £550 tops so my options are limitedYou could drop a 5900X into the current system. Future proofing with DDR5 and PCI-E 5 will cost as much as a 5950X.
ok....thats my thoughts exactly....want something new to play with lolI switched from a 5800X purely as it was something new, and after selling my old components cost very little.
