- 22 Jun 2018
- Doon the watah ... Scotland
Considering doing water cooling loop as a little project over time.
One of considerations being pump / pump res combo / block pump combo designs.
For reservoirs / pump reservoirs, you can obviously get different sizes of reservoir … does the size matter or make a difference to the performance of a loop?
Off the top of my head it might slow the rising of overall system temp due it adding a larger thermal mass to be heated , but wouldn’t change the final settled max if run for long periods ?
