- 1 Jan 2012
- Scottish Borders - UK
Hi folks.
I just installed this in my system.
It has one connector which I have connected to the CPU fan connector.
The 3 stock fans then connect to the bale that comes off the tubing at the radiator.
The VRM fan is spinning and the 3No fans are spinning, but the motherboard bios doesn't report any speed.
My thoughts are - how can the fans be controlled if no speed is reported?
I'm tempted to simply connect the fans to the motherboard and then have the pump header on the motherboard.
Searching online, others mention the 0RPM in the bios - but no information or fix.
Any help/input appreciated.
