11th Gen i7 or 12th Gen i5?
18 Dec 2021
Barrow in Furness, UK
Hi all,
I'm new to PC gaming and looking to purchase my first PC.
Do I go with the 11th Gen i7 or 12th Gen i5?
Both will be with The GTX 3070TI GPU and 16gb ram.
Thoughts, advice?
Thanks in advanced.
12th gen..not only does it beat 11th gen i7, you'll be able to upgrade to 13th gen down the line, something you cant do with 11th gen. 12 gen also means z690 board, so gpu slot is gen5 for future gpu futureproofing, and also has more m.2 nvme slots.
I'd also consider 32gb ram as prices pretty good at mo, and who knows ram usage in a couple of years..that and the switch to ddr5 prob means ddr4 prices increase as production decreaes
Thanks all for the advice. I'll most likely buy either Jan or Feb at the latest.
Keep a look out for Asus promotions... They generally have 1 every quarter.. Last one just finished gave £60 rebate off midrange board if biught with a 12600 cpu.
Ocuk are listed as a retailer but theyre pretty bad at advertising the offers
You get AMD offers too(got £50 rebate on my b550 gaming e board when i bought mine last year)
