- 18 Mar 2010
I bought a 3080ti Fe a couple of weeks ago, and will be ordering a new system to go with it in the next couple of days. One of the parts I have been umming and ahing about is the case, so I could do with some help!
I would welcome related cooling suggestions, like fan setup, and whether it is better to go with aio or an air cooler?
- The pc will be sat on the floor. It is a carpeted room, and it will be sat on either stiff card board, or a plank of wood. Either way I don't think a case setup to intake from the bottom of the case is a good idea.
- Side panels/rgb are not a positive feature. I don't think the inside will be looked at, and in any case it is likely only the right panel will be visible.
- Would like the case to be as quiet as possible! The pc will be in a communal open plan location, 2-3m from where people might be sitting on the sofa to watch TV, so would prefer that it is not too obnoxious.
), check out the reviews.
