- 22 Feb 2014
I replaced all of the euro cylinders when we moved in to our current house myself a few months ago, I took all of the locks out and measured them, then ordered locks with matching dimensions.
The problem I have is one particular lock was the incorrect size (although I didn't realise at the time) I assumed it was correct as I had matched it to the previously fitted one. The screw that held the lock into the door was not the correct screw either,more like a wood screw than a machine screw which I replaced when I fitted the new lock.
The lock itself sits about 5mm inside the handle on the inside and protrudes about 15mm on the outside. It has been fitted around 2/3 months and whilst it has been a bit finicky at times it has always locked so I didn't worry too much about it.
Last week or so I have been able to open the door after locking it, I then figured out if I turn the key as far as it will go then back to the position to remove the key from the lock the door remains locked. Again didn't think to much of it as it was doing its job
So tonight gone too lock the door from the outside and it has locked the door but the key won't return to the correct position so that I can remove it, I have tried a spare key on the inside but that won't turn either.
The lock itself is a yale superior euro cylinder.
What are my options now short of calling a lock Smith?
