No 5.1 to speakers on windows (via HDMI or Optical)
Caporegime
3 Jan 2006
Chadderton, Oldham
As the title, u can't seem to get 5.1
Via HDMI I only have the option of stereo or Atmos.
Via optical I only have options of stereo?
I have connected the optical cable to the "CD" optical port in my Onkyo onkyo tx-nr686
If I configure Dolby Atmos on HDMI I can configure so it's only got front, rear and center speaker, but will it just sound like 5.1?
Any ideas?
Cheers I'll have a look.
When I select Dolby Atmos, and remove the side speakers so it looks like a 5.1 config, will that be setting it to 5.1 in windows? The receiver is showing DD+ 5.1 and as far as I can tell it seems like surround? Not sure if I'll be missing some sounds though?
Send audio and picture to TV from PC and pass through audio to AVR, well that's what I'd do. Not much reason plugging stuff direct into receivers
Unless you have e-arc you won't get hd audio. Also depending on the TV may cause issues. I had drop outs, longer lock on, clicks on source change with TV being the hub and that is e-arc also. Going to the AV pre sorted it
I'm running HDMI 2.1 from PC to TV, then HDMI 2.0 from TV (LG BX) to reciever (Onkyo onkyo tx-nr686
