Build advice plz
There's been a significant fault found with these - a capacitor the wrong way around - which can cause fire. Stay away from them for the moment.
https://youtu.be/58a2VLXZd6A
That was one production line from what Jayztwocents says, and asus already issed a recall, so doubt if you ordered one now you'd get a defective board as suppliers really should have taken the bad ones off the shelves by now, seeing as the batch numbers have been released...easy to spot though now everybody knows about it
Just had a look its a "Thermaltake Tough power cable management 1200W" should be ok I think.
So if the SM961 SSD is a bottleneck and kinda pants what would be a lot better replacement?
Again many thanks for all inputs.
Dave.
Psu is fine and so is the m2 the sm 961 is no way pants and definately not a bottleneck.
Ahh sorry I was just repeating what someone said about it being a bottleneck. So I thought it was pants. Lol.
Thanks
Dave
Your welcome.
The sm 961 has read speeds of 3000 mb/s and write speeds of 1800 mb/s which is near maximum for pcie3 drive.
Do you have any other storage ?
Your welcome.
Yes m8 think about 5 others all western digital all used as just storage for all my **** I've collected over the years. Should have a clear out tbh.
Keeping my eye out for a asus 3080 strix card.
Thanks
Dave
Thanks
Dave
Was going to sugest that if you have lots small drives, do you have your games on a ssd ?
Thanks for your replies. I'll look into see what my stuff is worth then. Thought it was a trow away lol.
I just looked up FE PartAlert in telegram as I use that and only one I see in one in Deutchland. Can't see another.
Thank-you all
Dave.
https://t.me/joinchat/AAAAAEii3xT81U1A6tLjrQ
follow that link. If it's the same as the one you have then all good...if you scroll up you'll see the uk drops
I only have 1 game at mo and played it a very long time EQ2. And that's not on my SSD. Run just fine all the accounts lol
Thanks
Dave
If you get back into gaming then get your games on a ssd, m2 drive for fastest loading times.
Or even a large ssd for your projects to transfer on to will be so much quicker.
Well after phoning OC'ers up, I think getting a 3080 is going to be hard as still there's a massive shortage. And there not taking new orders as still have a massive pre-orders to sort our first. Dsmn
Dave
@Ardnik you need to remove the competiters name before the mods do for you.
No competiters are allowed to be menti0oed in forums operated by OCUK.
1 other question please. What monitor would you guys recommend to show of the 3080ti card. ? I already have a Liyama ProLite G2773HS (120HZ with 120hz and 1 ms response), along with a wacom touch screen.
I think I would like a 27" 4k IPS, as my main not sure exactly which one though as there's that many. What do you guys think something else or what type?
Appreciate it
Dave.
