New Budget Build
25 Oct 2017
Computer is on its way out...need a budget build mainly for my home business, so accounts and maybe some graphic design but very simple stuff. I feel I would favour speed.
I have done some research that has led me to think my ideal CPU would be the Ryzen 5 5600 due to the price point and it appears an good overall contender.
I would like 16gb ram as I always felt my current system with 8gb ran slow.
I'm happy to use the built in graphics for now.
Would i be better buying a pre-built system or building one myself which i have done a while ago as long as i can find everything that is compatible.
Budget is £600
Thanks
Thanks for taking the time to put this together, would Windows 11 be supported - is it the motherboard or processor that supports TPM.
Your welcome and yes win 11 is supported.
Tpm is ftpm in the bios for amd chips a quick Google shows more about it.
https://www.google.com/search?q=tpm...GYAQCgAQHIARHAAQE&sclient=mobile-gws-wiz-serp
You may need to update the bios on the motherboard for the cpu to work this can be done with bios flashback feature on the motherboard no need for another cpu to do it.
Loads of guides online .
