With £500 budget I'd rather go with Tomahawk or tuf gaming, or even stretch to the edge. They has more powerful VRM's and runs cooler than the Pro Z690-A. I guess more of a factor is using a 12900 where diff between the 2 boards is 14 degrees, but then 12700 diff is 5degrees at stock for Tomahawk,8 degrees for Tuf gaming, which will only increase if you're overclocking. Seen tomahawk for £245, tuf was same 2 days ago, but only seen £255 yesterday). The msi edge is next step up from tomahawk, bit of rgb thrown in, and vrm's go from 16+2 70A to 75A i believe, but haven't seen any price below the £289, so most expensive.
at the end of the day though, from what I've read, there aren't that many bad z690 boards, so get the one you like the look of with the connections you need, then just double check a review..and shop around
https://www.techspot.com/review/2381-intel-z690-motherboard-vrm/
https://www.tomshardware.com/uk/reviews/msi-mag-z690-tomahawk-wifi
https://www.tomshardware.com/uk/reviews/asus-z690-plus-wifi-d4-review
https://www.techporn.ph/review-msi-mag-z690-edge-wi-fi-ddr4/
My basket at Overclockers UK:
Total: £841.03 (includes shipping: £11.10)
