CPU Temp Issues.
21 Apr 2013
Hi. So a month back I upgraded my CPU to a 5600x, budget is tight so didn't really have enough to buy a proper cooler to go with it at the time, I've just been using the stock cooler which came with it.
Stupidly I have never really checked the temps, everything has been working fine so never bothered. The stock cooler has been pretty noisy but just put that down to the way this particular cooler sounded.
Anyway, last night when I shut my PC down after a session on Warzone, an error popped up after it had shut down saying something along the lines of "Warning - CPU overheating". Can't remember the exact words as it only briefly stayed on the screen.
That prompted me to check the temps next time I was on, so today I have downloaded Core Temp and loaded up Warzone, in game it reached as high as 87 degrees, guessing it would have gone higher if I'd have stayed on longer but only had time to briefly test it.
While just using Chrome etc it's at about 50 degrees.
I turned off the boost feature in the bios to see if that changed anything and it hasn't.
Are these temps way to high? I'm a bit scared to play anything now after that message as I don't want to damage my CPU.
The plan was always to get a proper air cooler once I had some spare money, this stock was just a stop gap until then.
Bit clueless when it comes to these types of things, any help would be appreciated. Cheers.
If you was getting the cpu overheat message you was at some point thermal throttling. As soon as you can get a better cooler. Anything over £30 would beat the stock cooler. So get a better cooler and that will sort the temp issue out.
Yeah thought as much, thanks. Can thermal throttling damage the CPU? I'm scared to play anything until I get a new cooler which should be towards the end of the week.
Also, have you used curve optimizor, that makes a difference, also maybe reseat the cooler, also I use Hardware info as a good monitor for your complete system
Thanks for your help guys. Much appreciated, eased my mind a bit. I'd already made an order before I saw your suggesting of the cooler unfortunately.
I went for a Noctua U12S Redux, will that be ok?
Haha thanks lads.
I've fitted my new Noctua cooler, just tested it with Warzone. Highest it got was 70 degrees! Result! Was hitting high 80's with the stock cooler.
Also, I don't know if it's just my mind playing tricks with me but my game felt smoother? Can thermal throttling effect performance in that way?
yes thermal throttling will affect in game fps as the temps increase the core clocks of your cpu will drop back quite a bit leading to less than ideal performance in games, but as temps are under control your cpu will keep boosting to it rates clocks and your game fps will be excellent :)
