So could I use a USB drive or does it need to be directly cloned to the new drive ?Unless you specifically tell it to
It won't copy empty space
So will just do 40gb
Thanks this was great help, ill check it out when I get a chance.Can do either method
If you have a usb to sata cable
You can directly clone to another hard drive/ssd
If not I would image rather than clone
So image stored on usb ,external drive etc
Put ssd in then restore the image
You can try to clone to usb then put ssd in
And clone the usb to it
It will just depend on your particular hardware if that way works
Obviously which ever method you use
Don't format the original hard drive
Until you know you've been successful
