So I've got this shelve and I've tried putting it up.
Firstly when I drilled into the wall, after about 5 or so mm the drill bit evidently punched into empty space so there is a large cavity.
I put the rawlplug that I got with the shelve and when I put the shelved up one screw wouldn't tighten, so I proceeded to take the shelve off and the rawlplug is now stuck in the wall .
I obviously need some new better rawlplugs but I have no idea which ones are suitable for a shelve on plasterboard?
Also how would I watch the drill bit size to ensure the correct drill bit is used?
Cheers
Cheers
