Images of items I have purchased (except trainers [no feet pics]) - Do NOT use imgur, postimage or imgbb!
New speakers arriving tomorrow to go with it.
Class D amp.. so they have a DAC -analogue-> Class-D -analogue-> speakers. Why didn't they just take the digital and run it direct to analogue? To convert DSD to analogue is literally an output filter :) (actually people have done this with tubes!)
Some more used tool bargains.
I wanted the 4 piece pick set but found this set for only a bit more than that would have cost
17mm combination spanner that was missing from my set.
A partial 1/2" deep impact set. I already had 17 & 19mm Facom wheel nut sockets so I'm only missing 13 & 14.
Yes, Z fold 3, quite impressive I have to say, although my 'old' note ultra 20 wasn't too shabby
I've been humming and ahhing over the Z fold 3 since i was due an upgrade but the fold would be anoying, i'm probably going to wait and see what the S22 brings in a couple of weeks and decide then whether to get the fold or the S22.
:eek:
They are all black teas in the pic, you can have them black or with a dribble of milk! I like having all my black teas with a little bit of milk as like the strength and texture that whole milk adds to any tea. They all have a unique fragrance because of the ingredients used.
Some people like to add honey, cinnamon, hint of lemon and even orange to add some zest too. All down to preferences and there is no right or wrong really.
There's a cafe / retail franchise here in New Zealand that you'd probably love!
https://www.majesticteabar.co.nz/
Hey I saw the KEF logo and suddenly sat up in my chair, scrolled up and saw the NAD D 3045 and had to stand up in excitement. You are in for a treat. KEF's Uni-Q drivers are supremely matched with NAD's sound signature. Fire up your favourite vocalists when you've got everything set up and you'll be in musical heaven for hours.
Aside from that, games and media sound superb too. Playing God of War currently and when the dragon speaks etc it's a deep rumble you can feel in your chest. I have the Q300 speakers so yours should sound similar although the bass reflex port on mine are front firing and I've not heard the 350s so not sure what difference the port location makes on these cabinets.
Anyway, you're in for a treat. On the 3045 make sure to not accidentally press the BASS/EQ button that changes the frequency output as you then need to cycle through them to get back to the default off state. It's not obvious you've pressed said button and the sound will get worse as certain frequencies are offloaded for output to a subwoofer etc which is of no use if you've not got one connected. Once you cycle through to "HP 40Hz" on the display, press it once more and that's back to the default mode then.
Also, having owned the D 7050 before the 3045, the 7050 did not have a dim display mode or display off mode button, always make use of the dim mode or manually turn the display off with the button. The VFD/OLED display will burn in after a couple of years if the bright mode for the display is used often. It's nothing major but looks annoying as you can see the weaker pixels when adjusting volume etc.
Don't think it matters on these NADs as the circuitry is lifted off their high end Master series amps. Really clean and direct sound.
