CPUZ Benchmark (all welcome)
OP
15 Jun 2012
Updated leaderboard again let me know if anything is out of place. Damn that 12900K has excellent single core abilities. However, looks like AMD shines in multi core, at least for the moment.
OP
15 Jun 2012
What is it missing. got the cooling,. the frequency, the voltage the scores and the CPU. 8C/16T is you don't know the CPU. Its a 65w part as stock but using 122W when overclocked
Didnt have TDP, or core count.... also nice to see voltage and things like that. Just please follow protocol going forward so i don't have to come back later and ask for incomplete data. Thank you.
14 Jan 2005
Lincoln, UK
Everyday Stock 5950X (3600 C14) settings.
Single 703.6
Multi 12729.9
5950X Dynamic OC All Core 4600 +PBO -25 all curve +50 Boost (3600 C14)
Single 707.2
Multi 13495.6
5950X Stock PBO -25 Curve (3600 C14)
Single 703.4
Multi 13547.8
PBO on its own can get to 4700-4650 giving a higher score. But it takes 1.4v just to reach 4600 All core and that's probably too high for anything other than quick benchmarks. Stock PBO doesn't seem to go far with single core though, same as stock in my case.
OP
15 Jun 2012
you should have the actual power usage not just TDP. mine is double TDP
Good point.
If you guys have OC TDP that would be like Ross is saying here. If not we will be forced to estimate from clock speed and stock TDP.
Also if you don't have any screenshots you can post your stats and I will add your sub, just be sure to post everything I need for a complete submission. Still just recommend the screenshots if possible tho.
5 Nov 2014
Update on mine, still stock but last time had stuff running in the background.
This Processor - 567.5 (Single Threaded)
This Processor - 4188.1 (Multi Threaded)
May give some overclocking a try but haven't done in years.
btw, the 9700K is a base clock of 3.6ghz and a 8C 8 T processor
19 Jul 2015
Since I have lost the top position already, maybe I can take last instead. This is an i3 3217U in an Intel NUC, completely stock. It was in use until recently, then it had to be replaced because it's a bit too slow. Overclocking would just make it overheat.
ST: 172.1
MT: 456.1
