I think the engine is the same. The interior has updated in various phases. I think this would be the last hurrah for them, with the move to electrificationI'm amazed you can still order these new. Is it still the same car from 2007?
Paying cash for it, so list price minus what we negotiated as discount. Not much off really, as the demand for new cars is so high. They matched some CarWow quotes but nothing that good.So what is the total to own cost e.g. if you got it on PCP/HP final amount that it would/will cost?
Had the wife's new since 2012. Currently sat on around 60k miles.
The 1.2 is dog slow, but does the trick around town. Once above 3kprm on the motorway it's not that bad to be fair.
At 50k the the gearbox input shaft bearing died (was grumbling for a very long time), at which point gearbox was out, new clutch etc. at the same time. I didn't end up with much change from £1k but that included a service and MOT. Rear boot electronic release is a well known failure point, but hasn't yet broken on ours.
Despite the gearbox, I'd say it has cost us very little overall. Servicing and consumables are all cheap and easy to DIY. It's ok on fuel for purely around town.
My wife loves it, hence we've had it for 10 years...
But I doubt main dealer servicing is cheap anywhere.Partial success - missus is getting an Abarth 500 as we found a combination of colours that passes the 'it must be pretty' test. At least it will drive better than the standard 500.
Brand new, arriving in April or so.
Yea mine came from a dealer with the wrong oil in it. The Abarth needs 10w-50 as they run hot. Motul and Petronas make a specific oil for it.The main downside of Abarth ownership was the pricing of parts and the quality of work from dealers, they were always putting the wrong oil in my car at serviceBut I doubt main dealer servicing is cheap anywhere.
Fortunately I didn't have much cause to visit much.
Bugger, that's one to look out for then, thanks.Yea mine came from a dealer with the wrong oil in it. The Abarth needs 10w-50 as they run hot. Motul and Petronas make a specific oil for it.
not so much of a heat issue in a Punto loads of room in engine bay.
I ordered an Abarth 3 weeks ago. The wait is 5-6 months. I'm hoping earlier, I'd be surprised if yours comes that fast.
Just the 595 - anything more than that was felt to be too boy racery.Which one did you go for?
