- 23 Dec 2015
How much are you paying for that system if you don't mind me asking? What area and who is installing it as well? It seems a decent system. Is the solis inverter a hybrid one?
I'm paying £8500 the company is TCLSolar in Lincolnshire it is a small family business but they have independent insurance/warranty. the larger companies seemed to only want to push products they wanted to sell, not what I wanted.
the inverter is a standard non hybrid 4G inverter as the givenergy charger/inverter handles the BMS/battery side side, they suggested the Solis as it is more proven and oversized so should be under less stress than the current 5KWh GE Inverter.
I should be able to get all the generation stats from the GiveEnergy charger/inverter, and they are developing a local access API for HomeAssistant so I can use this to monitor everything along with my current 6 channel CT clamp power monitor that monitors most circuits in the house
Will get phoning around some more based on the above!
