- 27 Sep 2020
Hi I have just purchased an Mini PC barebones kit,
MSI PRO DP20Z 5M
I got it to make a mini PC to use for a plex server and basic PC to have in the lounge. I already had a Ryzen 3 3200G (Zen+) from a previous PC build that used to work in my X570 motherboard. I installed the CPU and some DDR4 2666mhz ram, connected the HDMI to a port on my monitor and powered up. However it will not post, and Im struggling to troubleshoot what is wrong. The MSI website suggests the CPU compatibility on the data sheet is listed as:-
AMD Ryzen™ 7 5700G
AMD Ryzen™ 5 5600G
AMD Ryzen™ 3 5300G
The chipset is listed as AMD X300, and I would have expected the CPU to be compatible with the chipset. I am struggling to find out exactly if the CPU is supported. Cant find much info on either the MSI or AMD about whether the CPU is compatible with X300.
I guess I will contact MSI support tomorrow but any ideas in teh meantime would be appreciated?
MSI PRO DP20Z 5M
AMD Ryzen™ 7 5700G
AMD Ryzen™ 5 5600G
AMD Ryzen™ 3 5300G
