Anyone know anything about CO2 cylinders? (context: trying to refill sodastream canisters)
16 Nov 2002
The Moon
I know I can ring the place I bought it from but they are shut now and was wondering if the great folk of OCUK could help me with a bit of a CO2 related quandary this evening. I want to know if there is a way of telling if a CO2 cylinder has a drip or syphon tube inside from the outside of the cylinder?
I've basically picked up a 6.35kg of CO2 from a local gas depot so that I can give refilling our Sodastream canisters a go (it works out a lot cheaper than getting a refill from Argos/Tesco/SodaStream direct).
I've bought the appropriate valve from CO2 supermarket and we picked up a CO2 cylinder today to test it on but despite following the instructions we can't get it to fill at all.
I've read a lot about needing to make sure the donor cylinder has a drip tube or it wont fill properly but stupidly forgot to ask when we were picking it up. Ive read turning the cylinder upside down is a work around for this however it didnt seem to want to fill when inverted so i'm a bit confused what the problem could be outside of the drip/syphon tube.
My experience with various industrial gas cylinders, open the valve and gas comes out. You wont be able to recompress this gas into a liquid form in the sodastream cylinder and they are such a small volume they wont hold enough gas to be of much use so need liquid transfer through the syphon. In theory inverting the large CO2 cylinder should transfer as a liquid, be careful as its not the type of thing you want to be dropping especially not whilst inverted with something connected to the valve.
What canister did you get? I know our old welding canisters had safety systems built in to prevent them leaking when they were laid flat in the back of a van. Could that be it?
I got this - https://www.gas-on.co.uk/co2-10-ltr-(14lb) - a 6.35kg cylinder of CO2. It's been stored upright the entire time. I did try holding it upside down after several failed attempts to fill but it didnt seem to do anything differently.
As said above, I tried to do it upside down and had no joy. I called the place this morning to ask if they had a dip/syphon tube and he said he would get back to me as he wasn't 100% sure.
Some gas went into the canister, but not a lot (maybe 50g - weighed it after my fill attempt) as it was completely flat and I was able to use it in the machine again. I've put my canister in the freezer now though as apparently this helps the most with getting the most in a canister.
Im hoping it is just a case of me not having a dip tubed cylinder. The adapter i've got works fine as i've tested all valves etc without a bottle being attached, so it's either the tube being missing OR there is a real nack to getting the part which presses the pin down on the sodastream bottle to work and to dispense CO2 back.
