So, I get a fair bit of packet loss on my line (FTTC, ECI cabinet), I think due to a weak signal on the upstream.
I've found that I can virtually eliminate packet loss by using a free (unlimited) VPN called Proton, connecting via the Netherlands servers.
The important thing to enable is TCP. Any other protocol reported lots of packet loss. Using the default 'TUN' adapter is probably a good idea too. Advanced options off.
The other interesting thing to note, is that packet loss with the enabled VPN doesn't seem to increase when others in my home are using the same connection.
This does increase latency compared to the VPN set off, but not much.
I tested this using the following website:
https://speed.measurementlab.net/#/
Retransmission seems to be reporting as 0%, tested 10+ times.
The test server is located in Amsterdam, according to the results page.
Also, the latency would ofc be lower if you pay to use a UK VPN.
