- 4 Oct 2017
i upgraded to the asus maximus extreme x570 and now have a all core 4.7ghz core clock on my 5950x, i still run into problems if i try and push more, the all core clock of the cpu anyway is 4.9ghz with single core boost upto 5ghz, to get a all core 5ghz you need some massive cooling running, the cpu stock will drop clocks anyway to around 4.1-4.2ghz under full load.
dont feel too bad if your cpu is stuck at 4.7ghz, a all core oc at that still nets huge performance vs stock, the 5ghz is nice but that is only 1 core maybe 2 if you get a good chip, and if temps are too high it will drop back.
I wish it was an all core. The biggest all core I can get is 4.5
I was talking about single core boosts. Previously every core could hit 4.9ghz now they really struggle
