Hi there,
2 weeks or so ago a plumber came over to fix a problem in my bathroom. While he was there I asked him to do 2 other jobs in the house.
While doing one of those jobs, which should be really simple. It turned into something much bigger as the previous person did something on the pipe. This meant either it had to be fixed there and then or water shut off at the mains.
Basically one of those bum washing things on the wall I want to remove and just put on a stop at the end. Instead he had to remove all the tile around it as it was over-tightened and would leak when the water was on. He said the reason was that the previous person put it on way too tight, and there was no way for him to know.
I'm left with a removed tile with not a clue really how to replace it. Also the costs he mentioned are way over what I thought they were going to be in the end and now I'm pretty pee'vd off.
I wanted to trust him when he said its not his fault it happened but have I been scammed??
