Or the Britannia Unchained lot had their heads glued into so much American stuff, that they think the US is only market worth pursuing. Not sure where JRM fits in that, but Mr 1850 may thing the British Empire is still a thing and imperial measurements can act as form of protectionism like they used to do.Lol UK Gov attempts to force UK to use imperial.. which should make the exporting of goods and components really easy (sarcasm).
I thought the JRM was to remove the duplication.. perhaps JRM will suggest we go fully metric next to remove the complexity having to support both when the majority of our non-EU trading partners are Metric..
I must take exception to the letter in the December issue, on using the metric system. I was born in 1952 and attended school till I was 15.
At the age of about 9 in a maths lesson we covered the metric system. This was covered in the 1 hour lesson.
When in the next lesson we queried why we do not use it, the maths teacher set us a problem. The left hand side of the class would use our imperial system based on 12 and the other side of the class would use the metric system based on ten.
The problem was to divide 10 by 3. As we all know you cannot divide 10 by 3 in the decimal/metric system. So the left hand side of the class won.
He explained that the metric system was for 'lazy and / or idiots' so that they could count on their fingers. The imperial system based on 12 was good enough for the Egyptians to build the pyramids, so why would anyone want to argue with that.
The real problem with a metric system is that it can only be divided by 1, 2 and 5. Whereas the good old imperial system can be divided by 1. 2. 3. 4 and 6. We do not use decimal points, but fractions, which means that you always get an answer. No Pi equals 3.141592 and never get an answer for us. It is 22 over 7.
All my grandchildren can use the imperial system of measurement, because granddad taught them. An inch is about the length between the bent knuckle of the thumb and the end of the thumb. A foot is about the length of Granddad's feet. And a yard is one good stride.
I would suggest that Mr Vaughan does not go to a racecourse, because it is all in imperial measurements. The race distance is in miles and furlongs. The odds of a horse is normally in improper fractions, ie 100 to 30 or 7 to 2 etc.
Never play cricket, because the length of a cricket pitch is one chain long, and as all us old fogeys know there are 8 chains in a furlong, so we have no problems at a racecourse.
Do not rent an allotment from the local council as these are normally measured in rods. But they might just use poles, perch or lug as these are the same measurement.
When using weight measurements we have various measurements. If it is a ton you cannot lift it. If it is a hundredweight, you can. If it is a stone and it is over 12 stone you could be overweight. Then you come down to pounds, and we go smaller and have ounces, drams and grains. And all poor metric can offer is the gram.
I wonder if when he goes to a pub for a pint, he converts it and thinks. That was a lovely 568.261 millilitres of Summer lightning. Remember we have gallons, pints, and fuild ounces. All metric has to offer is litres.
This letter was in the current issue of a magazine I get and it's so appropriate that I thought I'd share it here.
OK, so what is the current time in metric and why are we still using a clock system based on 12 in this day and age?
You can't change the solar period regardless of what number call it.My watch says 4:72:35 Do you really want 10 hours to the day?
There are some oddities. For example the imperial va metric PVC-U pipe standards.
imperial is 4” inner diameter and the pressure class (thicker walls) changes the outer diameter.
Metric is 110mm outer diameter and the pressure class changes the inner diameter.
So imperial fittings and pipes are a pain as the sizes for the classes varies a bit for the same class). So they won’t fit. Got a class C and a class B you can’t use the higher class on a lower class pipework.
metric the pipe fittings work. A PN10 or a PN16 pipe and fittings have an outside 110mm diameter.
loopy.
Isn't that what the Stardate in Star Trek is supposed to be?My watch says 4:72:35 Do you really want 10 hours to the day?
Why would we want to drive on the right, like those backward Imperial-using Americans? Surely the only reason to adopt such a practice is so you can fire guns from wholly inside the car, or simply to be childish and stick it to the Brits from whom you just declared independence?Oh and also drive on the right... but I'd settle for metric as a good compromise!
there's a few conversions from driving trucks that stick...although they're not 100% accurate but they're commonly used like 90kph (limiter) is 56mph, or a 45ft trailer is 13m...even though trucks show the speed in KpH the computer usually shows the fuel consumption in MPG!
does anyone here measure fuel consumption in l/100km?
low bridges still have the measurements in imperial and metric...that's probably a good idea
same with fabricating/construction, an 8'x4' is a 1250x2540mm, or a 1/16" is 1.6mm, easy to remember but still not 100% accurate and rounded up/down
think I have some point here (figures based on a true life story)
