I need a bit of advice is possible. I need a couple of Pump Reservoirs for my rig. I've decided on separate loops for GPU and CPU and have already bought a couple of Black Ice Nemesis GTX 360 Radiators to go with them. This will be a hard line cooling solution and I have a case that can house the whole lot (Thermal take Level 20HT Snow) but I am struggling on deciding what to buy.
I looked at the ThermalTake Pacific PR22-D5 Plus but its very expensive for something that doesn't have PWM and doesn't get great reviews BUT it does fit the mounts in the case without any faffage.
The alternative I have found is EK-Quantum Kinetic TBE 300 D5 PWM D-RGB which is cheaper and apparently better but appears to have some strange side / horizontal mount which wont work with it. It needs to sit on a bracket which has 75mm mounting slots but I'm struggling to see how on earth I could mount it.
Thermal take Level 20HT Pump / Res mount
you can see the mounts at the front left and front right (yes its a massive case).
Stock image from the Thermaltake site of whats possible.
So any thoughts on how I could mount the EK gear?
