What car for 3k ?
23 May 2005
Poulton-Le-Fylde
Hi all, Im looking for a cheap car to put me on for a bit after mines been wrote off.
Ideally around 3k but would be willing to go up to around 5k.
Petrol, deisel, auto or manual I have no preference.
I dont commute in the car so thirstyness is not really a problem.
0-60 in 8 seconds or less, had to many slow cars.
Ideally I can fit my bike in the back and I do prefer bigger cars.
Ive had a few ford focus's, a octavia and have use of a 1 series BMW right now so none of them.
Ive seen a BMW series 3 320i 2007 with 60k on the clock and a BMW series 3 325i 2007 with 125k on the clock both similar priced at 3.2k, the 325i sounds like fun but high mileage.
Any input apreciated, I will consider anything if it fits my criteria above.
stay well clear of the 320i, the 325i will be the N53 engine i think and they can be troublesome too unlike the N52 before it.
I'd be far more concerned about how old the car is - very - than the mileage!
I think really the sensible option here is that if you've got a budget that small - and remember, everything is very expensive lately so what was once a £1k cheap car is now a £3k cheap car - then it's probably best to not be going straight to the BMW, Audi etc section of autotrader.
Because you'll end up with something thats basically at the end of its useful life in order to get a nice badge on the bonnet.
Volvo V70 D5, 05 or earlier if you don’t want a DPF ,I certainly wouldn’t be bothered about age or mileage with one of those,they are built to withstand both age and mileage with ease, and they do.
I’m on my second Phase 2 model, mines an 06 185bhp 6speed manual, it’s comfortable, reliable, good on fuel for the size of car although the earlier 05 plate 163bhp D5 it replaced was better on fuel and had the advantage of no potentially troublesome DPF…
I Previously had a 12plate Focus estate which I liked but it threw up a lot of bills at once,I was looking for a cheap reliable runaround and told to get one by more than a few people.
The 5 cylinder petrol models are thirsty but arguably even more reliable than the durable D5 diesels.
If you can get your head around the pipe and slippers with a Labrador in the boot image, they are excellent budget buys, and extremely comfortable to boot.
Mine was a temporary buy that I kept for well over a year in the end, and subsequently bought another to replace it.
Having owned a few older BMW’s over the years, the ownership experience of similar vintage Volvos is quite enlightening as to how a “premium” car’s reliability should be…..
Go for the E class above load of car for the money and seen reliable, as I said in a few weeks I will be buying a similar one
Spoken like a true OCUKer, the land of crypto Lambos and 50K EV vehicles. Peasants buying 3K cars need not apply.
It's more of a comment on the state of the used market to be honest.
There's nothing that fits the criteria for sub 8s and reliable in the OP's budget.
