Yeah I'm still open to different options, I haven't placed the order yet - any suggestions always welcome
I watched a ton of vids before choosing my mobo, weighing up performance as well as cost. Now if you plan on just having a lower endcpu that doesn't draw too much power, then most boards will suffice. If however you decided in a couple of years to drop a 5900X or 5950x to prolong the life of you rig, then vrm's on the mobo come into play. If you go to about 15mins in on the vid above, it gives a roundup of all the b550 boards he tested, and can see in a 1 hrs blender test with R9 3950 (so would draw more power to test the vrms), the pro vdh board is up to 79 degrees going up to 104 degrees when they pushed more power through it.
For me, though more expensive, I prefer something like the MSI Gaming edge which has far better vrm's, and therefore thermals keeping everything cool(or as cool as can be) If you don't want wifi, then the tomahawk is another option as slightly cheaper. These boards will easily handle a 5950X no problem, allowing a future upgrade no problem
I personally went with the Asus Gaming E as wanted wifi and front usb c support for front i/o(gaming f wifi didn't have the usb c front support) as it was on a promotion so got it cheap, otherwise would have gone with the msi option. but below are 3 boards I think are better if you think you'll upgrade cpu down the line...there's the msi gaming carbon also which is £10 more than the gaming edge if you require more usb sockets on the back, but runs warmer than the edge below(actually had that board but swapped it when someone told me about the asus promotion)
The gaming edge is new where as the other 2 are b grade. Unlike the b550 tomahawk, the x570 version has wifi, and both nvme slots are gen 4
My basket at OcUK:
Total: £431.05 (includes delivery: £11.10)
added the gaming carbon below so at least you could see it
My basket at OcUK:
Total: £180.49 (includes delivery: £10.50)
As said, only showing some other options . Vid worth a look anyway...he has 3 of them in total
