- 20 Oct 2011
Pretttttty gutted at the moment, I have double-checked on a 2nd system, stripped it down and checked everything, all the thermal pads were measured and the correct sizes used depth etc, 1mm replaced with 1 mm etc.
I have not had any issues with many other cards that I have repasted in the past.
The card lights up, and the fans spin, but no display at all.
I have checked cables.
There is no sign of bowing on the card, it went back together well, screws went in nice and tight.
It is an rtx 3090, it would still be under warranty as it is around 24 months old, but I guess with me breaking the warranty seal, the warranty with ASUS will be voided????
Any help or advice would be great, but a good repair centre recommendation would be great too.
