Firewire Card
29 Sep 2004
Wilt of the Shire
I've installed a Firewire card on in the PCI_E4 slot on my B550 Tomahawk board and it shows up in device manager. However, when I try to change the driver to the legacy one it restarts my PC every time. Trying to capture my late Father-in-laws videos via camcorder.
If anyone has used a firewire card and can help it would be greatly appreciated, thanks.
I know it sounds daft, but you might get a result through temporarily setting up a vm to run an older OS which is from nearer the time of all that kit. You could pass the FireWire card through to the vm and should see the camcorder .
that worked for me when I needed to run an old car diagnostic kit through a serial port.
