- 13 Sep 2010
Hi all!
With the recent addition of support for Zen 3 on certain x370 (and b350) boards, I thought I'd make the jump, in the hope it will last me for the next few years.
I picked up a 5950x from the MM and figured I'd post the results here for anyone who is considering doing a similar upgrade, hopefully it's helpful!
(I realised after buying the CPU that my other AM4 board - a Gigabyte AB350 Gaming - has also had support added, but I'm not sure the VRMs on that would handle 16 cores)
Overall the process was relatively painless, I flashed my board up to the required BIOS version, installed the chip and booted up.
BIOS flashing took about half an hour (as I had to upgrade to the bridge BIOS and then the final required version and ran some brief tests in between).
Before committing to the upgrade, I was concerned that my now ancient x370 board may not have been capable of running the CPU to it's full potential, but after running some benches I'm very happy with the result. 3dmark CPU score is a bit on the low side, but everything else seems in line with expectation.
Temps aren't much worse than my 3700x, multi-threaded loads seem a bit lower (around 55 degrees down from low 60s), but single threaded loads have gone up a fair bit, from around 60 to mid 70s (watercooled with a 60mm thick 240 and 80mm 'Monsta' 280).
ST boost is up from around 4.35 > 5.0GHz
Fully loaded up it's around the same (4.0-4.1GHz), hopefully I can get this up a bit with further tweaking!
I can post more screenshots for anyone who wants more detail, but the overall scores and improvement are shown in the below charts. (btw, RAM was 3200c14 before, now 3600c16....I think these are about equal, but the IMC seems a bit happier on this chip!)
