That's good to knowProbably overkill, but you shouldn't have any problems at all. I run Homeseer on an i3 NUC and it uses less than 5% of resources - Homeseer is similar to HAss.
That's good to know![]()
That's only got 2c2th but faster speed so one I'm looking at should be ok even though slower.I ran HA, my Router and CCTV on a G4400 before upgrading, it didn't even break a sweat with HA.
My HA machine is a bit juicy for something so small at 20W average.Does anyone have some typical running costs for their NUC's, i am keen to replace my rpi4 so that i could have HA/Plex/Wireguard + others all running on one system.
I just need to decide whether it's cheaper to have a NUC running alongside my NAS which means powering two systems, or if it'd better to just build a low powered SFF so that the NAS drives can be placed in the SFF.
There is (usually) already a proper neutral at the light bulb, so it should just mean replacing the bulb-to-switch wire. But as mentioned different houses often have quirks.Wouldn't adding neutrals require rather more rewiring than I'm anticipating?
That will work fine.There is (usually) already a proper neutral at the light bulb, so it should just mean replacing the bulb-to-switch wire. But as mentioned different houses often have quirks.
My solution for this is twofold but both involve buying the small relay modules that go inside the backbox (Shelly etc).
- Use your own switches of choice
- Set the relay unit to change state on change of switch position
- 3 switches? Fit 2 relay modules that do 2 lines each (best to ask for deep backboxes!)
- Use dumb bulbs of your liking. If you want smart bulbs anywhere, just tell the relay unit to stay switched on all the time but send an MQTT message to the bulb when the switch is flipped
I THINK this plan is going to work for my needs - which is that I DO want physical switches everywhere. I'm too reliant on having my hands full and needing to bash something with my elbow as I walk past. Plus guests need to use it easily. I'm not giving up any features of normal houses the last 50 years, only adding extra features![]()
If you're considering HA, do it!
I generally advise my clients to start with key infrastructure, which for any smart home is connectivity to the internet. Now for many enthusiasts, this will run to installing a lot of CatX structured cable to provide hardwired connection for devices that can be hard-wired. This can be a big job and involves chasing walls to bury cables. So before you go down that route I would start with installing some good quality wifi around the house, in the garden, and maybe in your outbuilding. This will involve running some cables and installing some access points which will then provide some of the infrastructures for your smart home. This will require some investment in a switch (to plug everything into), some wireless access points (there are lots of brands available), and some wireless access points.
Having good quality wifi around your house allows the majority of smart devices to have an internet connection and to talk to other devices. You already have 2 smart devices - smartphones and you will probably want/have one or more smart TVs or TVs with smart devices (such as firesticks). Allowing these to connect to the internet opens up a whole world of streaming media - such as Sky, NOW TV, Prime, Netflix, Catch-Up Services, etc
Ideally, you want a central point (sometimes referred to as Node Zero) where everything connects back to (your switch will be here) and where you locate other bits of smart technology, such as NAS, CCTV NVR, Hubs for other technologies, such as Zigbee and ZWave, Ideally, if possible, this is where you would have your Internet Router / ONT located, to make connecting things easy.
In parallel with installing your WiFi, you may want to think of some form of Security System (Burglar Alarm) to protect your property.
With good wifi and security, you can then begin to explore all of the available devices and technology on the market - Smart Speakers, Thermostats, Doorbells, Lights, Mowers, CCTV, Fridges, Coffee Makers, Showers, etc., etc.
This will also give you time to explore and think about a smart home hub (again there are lots to choose from - HAss, Hubitat, Homeseer, Indigo, to name a few), to integrate all of your appliances to form a truly smart home. The smart home journey is best undertaken with some form of route-map to what you wish to achieve. This would be the first part of that map.
Physical light switches were important to us so bought lots of Chinese ZigBee light switches from Amazon and installed them everywhere in the house (other than living room, struggling to find a ZigBee dimmer that will work with a high load). The switches also act as repeaters so great ZigBee reception everywhere.
Yes I work in this space. I have a side hustle as a Smart Home Integrator which I have done for 20+ years. Zigbee and Zwave do need their own hubs, yes. You may find that a high end domestic wifi router provides you with adequate wifi (its hard to know without seeing the property) but experience says that the best wifi is delivered using wired access points distributed around the property. As per my previous post, this will also form the backbone and core infrastructure of a smart home. Ideally running an armoured Cat6 in tandem with a buried conduit to the outbuildings will allow you to have wifi, CCTV, Security etc. I have done this for some of my agricultural clients as CCTV inside and outside outbuildings is becoming the norm these days. As the property is a Bungalow, installing APs on the ceiling should be fairly straightforward with the minimum of disruption. Happy to answer any questions that you have.
