Stupid question
1 Sep 2013
On my psu I've got a secondary switch it's not the main on off switch it's got 3 positions marked up o I and II what's this for
Can't get up in the loft to get the instructions at the moment
Cheers
Yes, it's possibly the input voltage; although that's usually just 2 position - 110V or 230V. If that's what it is then switching will cause a bang and the magic smoke will escape; so don't do it.
The other possibility would be a fan mode - fully passive, hybrid or always on.
What make/model of PSU is it?
Definitely not voltage it is way to easy to be switched for voltage it's a 3 position switch off and setting 1 and setting 2 I think it's the eco mode for the psu fan nothing exciting
Can't remember what make and model it is without opening it up all I know it's 750watt
